CWMS 2.5 SSO problem
Hi everybody,
After upgrading our CWMS from 2 to 2.5 SSO wont work any longer. It was working just fine before that. Now we get the following message:
SSO Redirection Failed
SSO protocol error. Contact your administrator for further support..
Any ideas?
Alex.
jsteinberg
Level 5
Level 5
Did you figure out this problem?
It appears that I was running into CSCur59123.    The CWMS 2.5 doesn't support SHA-256, so I had to change the Relying Party Trust config on ADFS to use the SHA-1 hash.
Thanks for the reply. In the meantime I integrated with CUCM and from CUCM to AD for auth. It was more a workaround then a fix but it got me going.
Thanks a lot again!
