3998
SZU CHI CHEN
Beginner
Dear Expert,VG224 problem about hook-flash transfer call
dear all
i have setup VG224 hookflash for call transfer,but not work
my analog phone have identify it support 130 ms for call transfer buttom
pls kindly advise the example config
tks again
10 REPLIES 10
matthewik.lee
Beginner
Check this bug
CSCeg42217: No dial-tone on hookflash if on-hold
Symptoms: Involves two parities (A and B in this example) who are in conversation. When A does a hook flash and tries to transfer the phone to the transfer target C, A will hear the dial tone indicating that A can dial an extension and connect to transfer target. In the mean time, B is put "on-hold" so that B's call is terminated but the call is still connected.
At this time, we block the hook flash handling. This will disallow the side that is put on hold (which is party B in our case) to make a transfer. This is to stop the chain of uncertainty if the party that is on hold wants to make a transfer.
Conditions: This is only applicable on the analog skinny endpoint connecting to Cisco CME and only affects the Cisco VG 224. No command-line interface (CLI) is involved.
Workaround: There is no workaround.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_release_note09186a008041df56.html
in my case phone a push flash buttom
it doesn't work
phone b will not hold
and phone a not appear dial tone
phone a and phone b still connect
tks
so i think it may hook-flash parameter problem
very tks
analog phone flash key frequency (can adjust)
earth
130 ms
260 ms
600 ms
Hi Jason. That's my case too...
I've tried many timing configurations and replaced the analog phone. Still looking for an answer.
Did you try to configure the max and min flash timer on the voice-ports?
voice-port 2/0
timing hookflash-in 140 120
or perhaps even 150 110 as max and min value
Problem with hookflash is that it is never exactly 130ms, especially not with the cheap ... phones
HTH,
Leo
I've found an answer for that on this forum!
I had to set "Maximun Number of Calls" on the device in CCM to 2 calls.
It worked this way:
- receive a call on VG extention;
- press flash, get a new line;
- call second extention;
- hook the fone;
The call is trasfered to the second call.
I had to configure stcapp correctly and activate call control feature.
I hope it help you Jason.
l.mourits
Contributor
Don't know if you had your problem resolved yet, but I ran into the same issue today (my first VG224 install) and found the simple solution.
Just configure the minimum and maximum hookflash timer under the voice-port in a way that it matches your hookflash time.
I have a hookflash of 100ms and had to configure this:
voice-port 2/0
cptone BE
timing hookflash-in 110 90
in your case it would be something like:
Hope it helps,
Leo
marinaibm
Enthusiast
Is it sccp or h323? With SCCP, it could be simply changing the busy trigger/maximum calls on the callmanger from 1 (default) to 2 so the phone could open an additional line for transfer
I've the same problems with Max. Calls set to 2 on CUCM 5.1.2.
Is there any workaround?
Create
Recognize Your Peers
Content for Community-Ad
