dial-peer issue
dszymkowicz
Beacause of customer requirements dial-peer match incoming and outgoing calls. All works fine, however for one BRI CLID is set and for another CLIR (clid restrict) is set. CLIR clears also CLID also for incoming calls.
How to differentiate dial-peers for incoming and outgoing calls?
9 Replies 9
paolo bevilacqua
Please explain what you want to do in other words, because what you wrote above cannot be understood.
OK
I am sorry for unclear info.
I want clid restrict for outgoing calls and no clid restrict of incoming calls.
regards
Do you have CM, CME or what else do you have ?
CM + GW with H.323
I am not going to do this on CCM but on GW.
Choose a prefix to hide CLID, like *67*
Make sure CM sends calls with that prefix to GW.
Configure a pots DP with that destination-pattern, bri port or trunk-group, and "clid restrict".
That should be enough.
I need this to do only on GW, so you idea is not an option for me.
thanks.
On GW I'm talking about.
