Disk input output problems when disk predicted failure in UCS220M3
charisma2848
Hi?
I have a difficult problem and want to get help from you.
We are using a UCS 220M3 server. The HDD is RAID-5.
However, there is a problem with one disk predicted failure in UCS server.
UCS has IP IVR and CUCM installed on ESXi VMware 5.1 base.
There is a problem that the IVR audio is not heard irregularly when HDD is predicted failure.
The CIMC version is 1.5 (3) b0.
Is there a way to solve this problem?
Thank you!
0 Replies 0
