DPA 7630 - Simple or Hybrid?
JoshMiller
Hi - situation is as follows:
CallManager 4.0.2 & IP Phones
DPA 7630 -> Octel VM
There is also a Definity G3 connected via T1/Tie lines. The Octel that is used by the IP Phones is NOT being shared between the Definity and the CallManager as the Definity is integrated with another Octel. (Customer is planning to use Octel Networking between the boxes).
We are integrating IP and TDM phones via the T1/TIE for dial-plan.
I presume this should be a Simple Integration and not a Hybrid Integration? The documentation does not cover this scenario in detail.
Thanks for the input!
vkapoor5
Level 5
Level 5
I feel that this is simple integration only.
carijit
If you are planning to use the DPA to also integrate the Octel to the Definity G3 then it should be Hybrid.
Simple is only for scenarios where Call Manager only needs to be integrated with Octel.
Depending on Simple or Hybrid the DPA decided whether or not to forward the commands like MWIC.
