Dropping outbound and Inbound calls
jummy1283_2
Beginner
Beginner
                   Just migrated over to SIP environment,Howver I am seeing sporadic drops of inbound and outbound calls.
I was also testing and found that my outbound dial peers are not workling properly
Even though i specified my local,longdistance,International and  Emergency Services dialpeer.
I have the translations and dial-peer configurations  below
voice translation-rule 1
rule 1 /^9\(.*\)/ /\1/
voice translation-rule 2
rule 1 /\(.*\)/ /9\1/
voice translation-profile prefix9
translate called 2
voice translation-profile strip
translate called 1
dial-peer voice 10 pots
trunkgroup 81_Atlanta_Outbound_calls
description "Calls coming in from Avaya PBX"
translation-profile incoming prefix9
destination-pattern .T
incoming called-number .
no digit-strip
direct-inward-dial
dial-peer voice 181 voip
description "Outbound Local 10 digit Calls"
translation-profile outgoing strip
preference 1
destination-pattern 9[2-9]..[2-9]......
rtp payload-type nte 98
session protocol sipv2
session target ipv4:100.240.224.1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 182 voip
description "Outbound Long distance Calls"
preference 1
destination-pattern 91[2-9]..[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 183 voip
description "Outbound International Calls"
preference 1
destination-pattern 9011T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 184 voip
description Service calls 411,911
preference 1
destination-pattern 9[49]11
voice-class codec 1
dtmf-relay rtp-nte
no vad
I need assistance in trobleshooting.maybe i'm missing something here.Thanks in advance for all your help.
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
What does the debug say about who ends the calls and reason code???
java
if this helps, please rate
Recognize Your Peers
