DSP replacement in virtulization
abdulkarim041
Level 2
Level 2
I have a concept a box with physical  DSPs must be used for VIOED conference calls. But someone told me we can use virtualized conductor and telepresence server with CUCM fro video conference call. is it right?
If right then let me know what is replacement of DSps.
BR
Abdul Karim
We dropped support for using DSPs for video conference almost two years ago, if that's what you were trying to do.
You need a video conference system, either conductor + vTP or CMS.
java
if this helps, please rate
Wayne DeNardi
If you are using CUCM, then you could possibly use a soft client such as Cisco Jabber instead of hardware TelePresence endpoints.  However saying that, the experience you will get from a properly configured TelePresence endpoint will always be better than a software equivalent.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Hi Wayne,
thanks for your kind response. Yes i am going to use CUCM. Kindly help me to find out the answer of below question.
If right then let me know what is replacement of DSPs.
BR
Abdul Karim
java
