Hi there,
We have a UC520 in our office and have a server logged in on skype which is forwarding incoming Skype calls to the Cisco UC520 with the following configuration on SIP2SIS:
*,sip:6999@192.168.0.7:5060
When calling we hear the auto-attendent on our UC520 and then we need to dial 0, 1 or 2 to connect to the correct extension. The autoattendent doesn't detect the input. The current DTMF settings are like this:
#Set to -1 to disable rfc2833 some providers use 96 most use 101
dtmf2833payloadtype=-1
#Use these for SIP INFO msg support - first is the most common type
#dtmfinfotype=application/dtmf-relay
enableSIPInbandDtmfDetector=yes
SIPInbandDtmfDetectorGain=1
SipDtmfDetectorHitThreshold=30
SipDtmfDetectorSilenceThreshold=50
#1 is default - set between .1 and .063 to help with mobile or poor signal dtmf detection
SipDtmfDetectorTwistAdjust=.063
#shutoff detector after time has elasped
autoDisableSipInbandDtmfDetectorSeconds=80
help much appreciated
