Echo cancellation disabled on 6608 gateway.
Randall White
Level 3
Level 3
I ran the "Show Voice Port Active" command on my 6608 gateway and noticed that the Echo Cancellation is disabled. How do I enable this? On the Catalyst CLI or the CCM Administration web page?
I am having some echo problems w/ the PSTN and want to make sure this is enabled before adjusting the Audio Signal dB.
Thanks, Randy
mowour
Hi Randy,
Verify whether or not you're not running into CSCea32399, which is a cosmetic issue.
Michael.
mowour
Hi Randy,
Michael.
