Highlighted
Beginner
Emergency Responder and Cisco 3850 Switches
I'm running Cisco ER V8.5, and recently installed new Cisco 3850 Switches. All the phones connected to the 3850 switches show a "unlocated" status. I've check the hardware compatibility Matrix for ER V8.5 and the 3850 is not on it.
What are my options for locating these phones in ER and assigning them to an ERL. Manually defining the phones? Is there a patch or update to ER V8.5 that would make a 3850 compatible?
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
Highlighted
Contributor
I haven't used the 3850's with ER yet so can't speak to that specifically, but generally speaking you have more flexibility using location by subnets vs switches.  Scalability-wise, you can add way more subnets than switches.  There's more going on under the hood if you're locating by switches so the process overhead is greater.
The only downside with using subnets is if you need to get more granular with your locations than your deployed subnets allow (ie a single voice subnet for an entire building but you need to define and assign locations at the floor level).  As long as you've been a little forward thinking on the route/switch side, you'll be fine.
hope that helps,
will
Highlighted
you need to upgrade to CER 9.0.1 for your 3850s to be compatible
6 REPLIES 6
Highlighted
Contributor
hope that helps,
will
Highlighted
Highlighted
Beginner
Cristobal, thanks I just read the release notes for CER 9.0.(2) and they concur with your answer....Thanks!
Highlighted
Could you theoretically add
Could you theoretically add all of these manually and they would work? I realize you wouldn't have the switchport tracking, but as a temporary workaround?
Highlighted
Beginner
Thanks Will, but this customer of mine didnt do a good job subnetting so there is one voice subnet throughout this 2 story building and we would like a little more location grandularity.
Highlighted
Beginner
Weird, I'm on 9.0.2.10000-1
Weird, I'm on 9.0.2.10000-1 and still see:
2014-12-02 00:09:23,036 | INFO  | CER_AGGREGATOR | This device is not supported
For my 3850s
Any gotchyas for these?
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
