Error running avvid_save
Sandy Lee
Level 4
Level 4
I have lots of CTIManager errors in the EventViewer and it seems that it's a directory issue. I'm trying to run avvid_save and I get the following error "ldap_simple_bind : invalid credentials". I can't log in the DC Direcory Administrator either, no user/pwd seems to be valid. Any ideas ? Thanks.
gogasca
Level 10
Level 10
Are you using DC Directory or AD directory Integration.
You might check the Directoryconfiguration.ini files and UMDirectoryConfiguration under:
C:\dcdsrvr
C:\dcdsrvr\
respectivly.
This will give the current options for your Directory
Can you add/delete/modify users?
Check this link:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_3/trouble/3_3_3/tbl33ch5.htm
http://www.cisco.com/warp/public/793/access_dial/dc_directory_password.html
Which error you are getting in the EV?
Gonzalo
Hi Gonzalo,
It seems that the problem was with MLA. I uninstalled/re-installed it, created the "ac" user, and everything is fine now. I could'nt do any of the procedures in the Directory issues guide, I was always getting an error.
Thanks.
