Evaluation of e911-chicago for struts2-jakarta vulnerability CSCvd51442
rehan1786
Bug Search Bug Search Tool - Cisco
CSCvd51442
Conditions:
Exposure is not configuration dependent.
This vulnerability affects 11.0 and 11.5 releases only.
Last Modified:
Mar 24,2017
Status:
Fixed
Severity:
2 Severe
Product:
(1)
Cisco Emergency Responder
Support Cases:
Known Affected Releases:
(1)
12.0(0.98000.50)
Known Fixed Releases:
(1)
12.0(0.98000.55)
My Only question whether is it impacting 11.5 version or not. Because its not very clear Know affected release its only stated 12.0 version.
Can someone please verify.
Rehan
Jaime Valencia
The list of affected products that have been confirmed, is in the security advisory from the bug
https://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20170310-struts2
java
if this helps, please rate
Thanks Jaime,
But as per cisco 12.0 version is not released yet.
The notice has fix for CER 11.5 with date of April 10th 2017.
The Call Manager fix has date of 3-31-2017 but I see no update patches on CCO for Call Manager build 11.5.1.13900 yet which should be SU3.
Same for IM&Presence, the bug mentions fix 3-23-2017 in 11.5.1.13900 but no 13900 version on CCO yet for download as of 11pm MT 3-31-2017.
Are there going to patches for Call Manager, CER, and Unity Connection 11.0.x for this?
Erick
