Expressway XMPP Federation - Priority issue
Enric92
I have an issue when trying to federate Jabber with Skype via Expressway (XMPP federation).
For example, if the federated domain is : example.com
Nslookup _xmpp-server._tcp.example.com
primary.example.com Priority: 0 Port: 5269
backup.example.com Priority: 10 Port: 5269
The expressway will always contact: backup.example.com.
But it should be primary.example.com since the priority number is 0.
Expressway Version: 8.9.2
Ammar Saood
do you have Cisco CMS installed ? which version ?
what is your Expressway version ?
B2B federation with O365 or public skype is only possible with CMS, imp11.5su2, EXP8.9.
did you apply for Public federation to federate Skype with your EXPE server?
AMMAR
please rate and mark answered if heplful.
It's not a complete Skpye for Business federation, only XMPP Presence/chat federation so no CMS.
My Expressway version is up to date: 8.9.2.
My problem, the expressway always target the SRV record with priority number higher (So priority lower).
Under same scenario i am also facing issues;
is it inter domain or intradomain ?
I dont think so im & p supports xmpp federation with skype for business, it supports sip federation
can you provide the link for the document you followed for deploying ?
Thanks in advance for your suggestions
