06-10-2008 06:49 AM - edited 03-13-2019 05:20 PM
I am looking for assistance on Extension Mobility. We currently have several sites with different phones. When I try to log in to Extension Mobility on a 7975 with the profile as a 7961 I am only seeing the first 2 line appearances, but on the 7961 it is working fine. Is there a way to setup a universal login for every model so the users can login to both 7961 and 7975 without issue?
Thanks for any assistance.
Jason
Solved! Go to Solution.
06-10-2008 09:52 AM
you need to configure default device profiles for each and every model you plan to use, that is covered under the EM guide
javalenc
if this helps, please rate
06-10-2008 09:52 AM
javalenc
