Within CAR under System Param-->Gateway Config
What does MAX No. Of Ports actually mean? I reaqd through the online help, but can't determine if it's actually channels on a PRI or if it's ports on the card. Anybody have a suggestion what this value represents? I imagine if CCM/CAR knows that it is a 6608 PRI, then it would assume 23 channels. But it actually defaults to 0 and I need change it to something. So should it be 1 or 23? Will it even matter? I ran some reports and it looks like an accurate representation of the utilization, but I need to be certain...thanks!
