Fast dials/speed dials
Aaron Harrison
Easy question of the day - if I use the CCMUser pages, I can set up speed dials that appear on buttons... no problem.
If I set up speed dials that aren't button-associated, how do I dial these from the phone? I was under the impression they'd appear on the fast dial service but this doesn't appear to be the case...
Ta
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Chris Deren
If you have that service configured, all you need to do is go to the service and you'll see list of unassigned dials, simply press the assign softkey.
The service url:http://ip/ccmpd/xmlFastDials.asp
Paramenter:
PreDial
UserID
UserPIN
Chris
Hi Chris
Thanks for the response - I do see the list of unassigned dials, but what I expected was to see the speed dials I configured on the CCmuser pages...
These must appear somewhere - or what's the point in adding them?
Aaron
The speed dials are only associated with the buttons, they do not appear in the service. Based on your phone template you'll under ccmuser speed dials you see number of lines setup for speed dials.
Chris
mparekh
Level 3
Level 3
The speed dial number not associated with the buttons will work with Abbrivated Dialing.
So dial the speed dial number associated with the number you are trying to dial and then click on the AbbrvDial softkey.
