03-31-2004 12:55 PM - edited 03-13-2019 04:29 AM
I have a 3725 running CME 3.1 with a fax machine connected to an FXS port. Since the upgrade from CME 3.0 to 3.1 I have been unable to send faxes. Fax machine gives a communication error. It dials and starts the connection to the destination fax then fails.
Here are excerpts from the config. The only thing that changed was the CME to 3.1 and the IOS to 12.3.7-T to support CME 3.1
Calls come in on a T1 PRI
voice translation-rule 23
rule 1 /1569/ /1111/
voice translation-profile 1569_Calls
translate called 23
voice-port 0/0:23
voice-port 2/0/0
voice-port 2/0/1
dial-peer voice 1569 pots
translation-profile incoming 1569_Calls
incoming called-number 1569
direct-inward-dial
port 0/0:23
dial-peer voice 1111 pots
description Calls to Analog Fax
destination-pattern 1111
port 2/0/0
Thanks.
04-09-2004 06:53 AM
check if there is any codec mismatch.
04-09-2004 06:37 PM
Try this configuration on both ends, it fixed a number of fax issues we ran into...
voice service voip
fax protocol pass-through g711ulaw
