AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
806
Highlighted
Contributor
Flash payback on DMP4310
With DMP4400 I was able to play SWF flash files. But it wasn't very smooth if the file contained some heavy animation such as  Power point-like transitions.
My question is about DMP4310G. AFAIK it supports Flash Light animations. Does this mean that one can play normal SWF flash files? If so did anyone try it?
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Flash payback on DMP4310
Hello!
That model supports "Flash Lite 3.1" as described in the data sheet. Flash Lite is a simplied version of flash designed to run on mobile or low power devices. It is not compatible with all features of flash.
The key features of Flash Lite 3.1 are:
  • ActionScript 2.0 support only
  • compatible with Flash player 9
More information about this can be found http://www.adobe-flashlite.com/ http://en.wikipedia.org/wiki/Adobe_Flash_Lite or http://help.adobe.com/en_US/flashlite/dev/2x3x/WS5b3ccc516d4fbf351e63e3d118d293d38a-7ffc.html
I've found that in CS4 you can check if your flash file is compatible with Flash Lite 3.1 using an emulator: http://help.adobe.com/en_US/flashlite/dev/2x3x/WS5b3ccc516d4fbf351e63e3d118d293e4ad-7fd5.html
A simple test is that Flash Lite 3.1 is also used in the "Internet Channel" on the Wii, so buy one for testing .
I hope this is of some help for you.
Best regards, Peter
2 REPLIES 2
Hello!
Best regards, Peter
Contributor
Thanks pevaneyn. This is really very useful. About the WII option, I will certainly think about it
Content for Community-Ad
August's Community Spotlight Awards
