fxs blade problems modem negotiation
a.wells
I have modems connected to the pots ports of fxs blade in cat 6509 somtimes when I dial another modem it keeps trying to negotiate connection.Other times they connect straight away.
Is there any settings that need to be tweaked to fix this.
mimckee
It really depends on with the 6624 is talking to. What gateway are you using to go to the pstn or where ever you are trying to establish with the modem. You will want to get on the lastest loads for the 6624 but it really might not help depending on the other deivce. If it is 6608 and that is also on the latest loads you should be good to go.
Thank you,
-Mckee
We are useing CM 3.13a spc gateway being used is Digital Access WS-X6608 D00403010043.Analog Access WS-X6624 is uesing A00203010037.
