08-01-2018 06:45 AM - edited 03-13-2019 10:18 PM
Running IOS-XE 16.07.01 on a 4431 - was wondering if anyone has a good way (without 3rd party apps) to get a maximum current calls say on 5 minute intervals?
I'm not programmer but I know these days there is an embedded guest shell in the 4431s. I'd be looking for something simple like periodically running the commad "show call active total-calls" and geting the value and then populating a file on flash or similar that I can then use to graph
Any one done anything like this?
08-01-2018 08:51 AM
08-01-2018 09:47 AM
thanks. That would be a helpful start
