Get Historical Max concurrent calls on CUBE
rchaseling
Level 4
Level 4
Running IOS-XE  16.07.01 on a 4431 - was wondering if anyone has a good way (without 3rd party apps) to get a maximum current calls say on 5 minute intervals?
I'm not programmer but I know these days there is an embedded guest shell in the 4431s. I'd be looking for something simple like periodically running the commad "show call active total-calls" and geting the value and then populating a file on flash or similar that I can then use to graph
Any one done anything like this?
R0g22
Nothing native AFAIK. You can either enable CDR (gw-accounting) or setup a EEM script to capture the outputs against a 300 second watchdog and send the file to flash. Look up CSC. I provided an EEM a while ago to someone with something similar. I will see if I find the post. Will link it here if I do.
thanks. That would be a helpful start
