AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
1245
Beginner
H.264 part 10 with DMP 4400G Problems
We are using Final Cut Pro to export all our video content for our digital signage on our campus. We have tried numerous times to export an H.264 video with various settings and can't get any of them to work. Does anyone know what we could be doing wrong? It is clearly stated that the 4400G supports MPEG 4 part 10 which is clearly H.264 video. Any help anyone could give us would be greatly appreciated. Thanks in advance.
DMM 5.2.2
DMP 4400G running 5.2.2
Everyone's tags (5)
4 REPLIES 4
Re: H.264 part 10 with DMP 4400G Problems
Jonathan,
This should work if you use the correct settings in FCpro.  Please relay to us which settings
the you are using for H264 when rendering the files.  Also, verify that you are using the
mpeg-ts container wrapper for the media content.
You can also download a media content analyzer at:
http://mediainfo.sourceforge.net/en
and then evaluate the media file and copy\paste the TEXT view into a text file and
attach to this discussion.
Also, please defined the symptoms or issues that you are seeing with the FCpro
files playing on the DMPs.  And if you have a small sample file to upload that
would also assist in narrowing down the issue.
T.
Highlighted
Beginner
Ok, I'm pretty sure I'm not using a mpeg-ts wrapper. How do you do that from FCpro? Here is what MediaInfo spit out regarding my test video file that will not work:
General
Complete name                    : /Sequence 4.mp4
Format                           : MPEG-4
Format profile                   : Base Media / Version 2
Codec ID                         : mp42
File size                        : 15.5 MiB
Duration                         : 20s 982ms
Overall bit rate                 : 6 208 Kbps
Encoded date                     : UTC 2011-03-21 22:31:19
Tagged date                      : UTC 2011-03-21 22:31:19
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : Main@L3.1
Format settings, CABAC           : No
Format settings, ReFrames        : 2 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Bit rate mode                    : Variable
Bit rate                         : 3 040 Kbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Display aspect ratio             : 16:9
Frame rate mode                  : Constant
Frame rate                       : 30.120 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.110
Stream size                      : 7.61 MiB (49%)
Language                         : English
Encoded date                     : UTC 2011-03-21 22:31:18
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Thanks for the help.
Beginner
Forgot to mention the settings I'm using to export...
Export Using Quicktime Conversion
Format: Quicktime Movie
Compression: H.264
Quality: High
Key Frame Rate: 24
Frame Reordering: Yes
Encoding Mode: Multi-pass
Dimensions: 1280x720 (current)
No Audio
Jonathan,
The DMP requires MPEG_TS to play the mpeg4 video content.
I am not a FCP user so i do not know the exact steps but I included
as document that may help you.  You can export the FCP video
file to mpeg2 in mpegTS.
I hope this helps!
T.
Content for Community-Ad
August's Community Spotlight Awards
