08-27-2002 09:11 AM - edited 03-12-2019 08:31 PM
Hi folks,
had recently tested out a H.323-based voice gateway with 2 CCM (Publisher & Subscriber). As norm, we had the subscriber as the Active & Publisher as Standby for failover.
We then made a call out to the PTSN from an IP Phone, had the Subscriber CM services stopped, and expected the Publisher to failer over immeditaely w/o dropping the ongoing call. However, the call dropped & there was a message displayed on the IP phone indicating the CM has fallenback, and features were disabled. It then took about 20 to 30s for the IP phone to be reverted to the Publisher,but only after some push of the phone's button.
This wasnt the case when MGCP was used for the gateway.
Below is a brief description of my configurations. Would appreciate any feedbacks/comments. Btw, using CCM 3.1.4a, IP Phone firmware 4.8 & IOS
12.2.10B.
dial-peer voice 100 voip
preference 1
destination-pattern 6370....
voice-class h323 1
session target ipv4:10.228.204.5
dtmf-relay h245-signal h245-alphanumeric
codec g711ulaw
ip precedence 5
dial-peer voice 1 pots
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 2/0:15
dial-peer voice 101 voip
preference 2
session target ipv4:10.228.204.4
codec g711ulaw
ip precedence 5
Thank u!
08-27-2002 07:54 PM
I'm pretty sure that's expected behavior. In an h.323 call, the CM is actively involved in the call and acts as a 'middle man'. If the CM process fails, is stopped or otherwise becomes unavailable, the call drops as you've described. MGCP doesn't have that limitation because the gateway and phone can communicate directly without the intervention of CM once the call is up.
At least that's how I understand it.
HTH,
Vance
08-28-2002 12:00 AM
er hunh, then whats the point of failing over when the ongoing call will be disrupted despite claims being made that existing calls will not be dropped, unless MGCP is used..? Is there any way 2 smooth out this H.323 failover transition ?
Any advise ? Thanx!
regards,
seanwy.
