Beginner
Help to build wireless network for computer lab
In our school, they are planing to build a wireless network for a computer lab.
We need to know what HW devices (Router,switch,AP) are suitable to acomplish that ?
There are a lot of options and models for routers, switches, APs, we would really appreciate your help to determine the number of required APs and the suitable router and switch, knowing that computers have built-in wireless network card which will be used to connect to APs.
We would really appreciate your help and support.
Everyone's tags (1)
1 REPLY 1
Highlighted
Beginner
Hi,Did you ever get this
Did you ever get this implemented? What hardware did you use?
Content for Community-Ad
July's Community Spotlight Awards
