help with CMK Simulator and SoftPhone
albertoocdc
Hi.
I´ve been reading in this forum some messages saying that I can develop XML Services using IP Communicator and Call Manager SImualtor.
I´ve installed CM Simulator and the, installed SoftPhone 1.3(3.0). In the installation process it says me to input the CM Version installed (3.0, 3.1, 3.2 or 3.3)
Wich one do I have to enter?
Can I develop using that version of SoftPhone?
stephan.steiner
The simulator simulates CM 3.3.
You can develop services as long as you restrict yourself to only do services that do not touch the call manager (AXL is not possible, neither are applets that run on the CM like the WebDialer or Extension Mobility). Also, multicast streaming seems to be off limits as well for whatever reason.
