Help with NM2V/E&M and a 2651
avmabe
Level 3
Level 3
Hello all,
I just installed a NM2V with a VIC2-2EM into a 2651 router. I can't for the life of me get the router to recognize the boards. I've tried a few IOS versions (12.2 8T5) and (c2600-ipvoice-mz.123-4.T4.bin) which was recommended by our SE. Neither work.
Any quick suggestions. Is this hardware not supported on the 2651? Do I have to have a specific IOS? I'm at a loss here.
Anything is appreciated!
hattingh
This NM-2V HW is supported in the release/platform you're using, but you cannot use a VIC2 card in an Nm-2V. The NM-2V supports only the older generation VIC- cards. And the new generation NM-HD-1V/2V supports the VIC2- cards. Check the datasheets for details of the lists of equipment supported.
hattingh
Christina,
100 percent on the money. Kudos.
I have shipped out VIC-2E/M cards to the customer. I do appreciate the reply. That saved me a ton of grief ;)
