06-03-2002 12:08 AM - edited 03-12-2019 07:04 PM
HI ALL !!!
PLZ, help me !
I think this is Cisco IP Keyswitch.
But the question - whether it will work, if 5350 and 7960 are in different cities, and certainly in completely different subnets, divided alied routers, and by the document from link, 7960 address receives on DHCP from 5350.
As far as I remember DHCP works only in the LAN.
Whether means in my case to connect these devices it is impossible?
So I understand?
Thanks ALL !
06-10-2002 10:59 AM
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources online at http://www.cisco.com/go/solutions. You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit http://www.cisco.com/warp/public/687/Directory.shtml
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
06-14-2002 12:03 PM
The ip keyswitch is supported only in 1750,1751,2600,3600, 3725,2745 and IAD 2420. In case that you use one of this routers, you can use the command "ip helper-addres" to resolve the issue about DHCP ( its works in lan enviroments), this command redirects all the local broadcast to a unique ip address ( your router, in another network).
MaNuk
