How do i receive input from remote control? (DMP 4310)
songchai.sud
I am developing the content on DMP 4310g which have to developed by flash action script 2.
I can play video and any text following a manual attached with this discussion.
The problem is there is no the idea about remote control on that manual.
Can any provide some solution or manual?
5 Replies 5
sdhanral
Can you rephrase your question ? Are you trying to use the remote control on the 4310 to change the presentation on the display ? Are you looking for a remote key mapping document for 4310 ?
Sagar
->yes, i am trying to use the remote control to change the presentaion on the display.
   My presentation is a button list that can be pushed when you push the button on remote control.
   My actionscript is a key listenner that will be fired when key down.
Attached is the document that will assist you achieve the mapping on Remote keys in "4310" to a particular function, like assigning the red key to play CONTENT A, BLUE key for CAST etc ,
It may assist you somewhat and you can tweak it to your needs. I believe your scenario is different - more of a content creation issue, you want the remote key to control an asset and simulate a button press in your presentation, I'm not sure how that can be achieved or if the document can be helpful there but you can try.
Note : The process assumes you have a Web Server - Apache or IIS.
Sagar Dhanrale
Document :
https://supportforums.cisco.com/docs/DOC-20631
The link to this document https://supportforums.cisco.com/docs/DOC-20631 is no longer valid.  Does anyone have this document that could repost or send to me?  Thanks.
-Adam
Hi Adam
I think you should find them in one of the two PDFs in the zip I have upload for you:
https://www.dropbox.com/s/298vnooqyci0tlh/DMP4310.zip
Cheers
Ali
