How to configure edge switch 3550 with Ip phone attached to it ?
kareem
Hi Everybody,
I just want to ask the best way for configuring edge switch 3550 or 3560 with cisco ip phone and pc attached together to its ports.
which one is better:
configuring ports as trunk and define voice vlan and native vlan for data.
Or configuring the port as access port for the data vlan plus definig voice vlan.
Any one could help me.
Thanks...
thisisshanky
Level 11
Level 11
I have seen both methods being used in the voip world. One advantage i can see with the access port for data vlan and a separate voice vlan type design is that, you can simply plug a PC straight into the switch port and it will work. In the former case, since the port is trunk port, only IP Phones can be connected to them and the PCs will have to be connected behind the phone.
Hope I am clear!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
jraarons
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a00800c9fda.html#xtocid5
Here is a config from a device;
interface range FastEthernet0/1 - 24
switchport access vlan 303
switchport voice vlan 110
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
