02-26-2019 10:41 AM
Hello Guys
I am trying to send CARD REPORTS to my email using an SMTP PUBLIC SERVER HOTMAIL with this information that I found in Internet.
And in the configuration under system --> system parameters --> Mail Parameteres I filled it with the following information:
But when I try to send email I got the following error message:
Error Code | Error Description |
10011 | System Error. Contact System Administrator. |
I can't use a public SMTP? The configuration is wrong?
02-26-2019 11:36 AM
what version of CUCM, i see some bug around same error:
https://quickview.cloudapps.cisco.com/quickview/bug/CSCve58538
if not bug for your version, do you have any FW in between from DEvice to internet ?
02-26-2019 11:46 AM
Hello
I have the following version
02-26-2019 12:37 PM - edited 02-26-2019 12:38 PM
Try below option (if no FW blocking).
you can use this gui to test from your network.
https://www.motobit.com/util/hotmail-smtp-pop-outlook.asp
02-28-2019 07:54 AM
Hello
I created a private SMTP and I could send the email.
I think the problem is that hotmail doesn't use port 25 to SMTP because port 25 is unencrypted data, the same to gmail and yahoo, so I think the only solution is to use a private SMTP.
