07-20-2009 06:04 AM - edited 03-13-2019 06:31 PM
Have you got any idea how to monitor AXL requests sent to the CUCM and processed?
I would like to know if there are any applications which can help me to watch the amount precisely.
Now, the better way I have is to check with netdump/tcpdump - wireshark and log of "AXL Web Service"
[EDIT] But AXL Requests are encapsulated in https... [/EDIT]
Thanks in advance for your answers !
07-22-2009 11:28 PM
With rtmt, you can get realtime display of the axl logs (and for ccm4 you can run tail on the ccm to get the same.. just rdp into the box and run tail on the axl logfile)
there's also the soapmonitor (https://
I'm in the fortunate position (well, fortunately is relative since writing and adapting that code to newer version requires quite a bit of effort) that I write my own xml code and thus have means to dump request and responses locally
07-28-2009 07:23 AM
Thanks for your answer,
Finally, I came to this solution too.
This is not user-friendly but it helps a lot.
