I'm having problems to activate LLQ QoS in a Data Network.
admin_2
Level 3
Level 3
The data network is working appropriately. When I trying to activate LLQ QoS in the network, the voice listen with distortion although the LLQ queues are working. I have a Cisco 3660 in the primary site and Cisco 1750 in the remotes sites with Bandwith of 128 Kbps and Cir 128 Kbps.
To information way I must indicate that the connection is full almost all along but I have understood that when Quality activates on watch the voice would have to work with priority on the data.
7 Replies 7
Vance Krier
Level 4
Level 4
Can you post your configs so we can have a look?
Vance
Here configs:
Principal Site:
ip subnet-zero
no ip domain-lookup
ip name-server 200.44.32.12
ip name-server 200.44.32.13
class-map match-all calidad
match access-group 102
class-map match-all signaling
match access-group 103
policy-map voice-policy
class calidad
priority 36
class signaling
bandwidth 8
class class-default
fair-queue
call rsvp-sync
fax interface-type modem
mta receive maximum-recipients 0
interface FastEthernet0/0
ip address 192.168.2.1 255.255.255.0 secondary
ip address 200.44.49.129 255.255.255.240
no ip mroute-cache
speed auto
half-duplex
h323-gateway voip interface
h323-gateway voip id BIBLIOTECA ipaddr 192.168.2.1 1718
h323-gateway voip h323-id central
h323-gateway voip bind srcaddr 192.168.2.1
interface Ethernet2/0
no ip address
shutdown
half-duplex
interface Serial2/0
description Enlace con Internet de CANTV
no ip address
encapsulation frame-relay
no ip mroute-cache
no fair-queue
interface Serial2/0.178 point-to-point
description Enlace CANTV
bandwidth 2048
ip address 200.44.108.142 255.255.255.252
ip nat outside
no ip mroute-cache
frame-relay interface-dlci 178
class voip1024
interface Serial2/1
description Enlace con las Localidades
no ip address
frame-relay traffic-shaping
interface Serial2/1.30 point-to-point
bandwidth 64
ip address 192.168.11.1 255.255.255.252
ip nat inside
frame-relay interface-dlci 30
interface Serial2/1.100 point-to-point
description Enlace Fco Miranda
bandwidth 128
ip address 192.168.40.5 255.255.255.252
ip nat inside
no ip mroute-cache
frame-relay class voipovfr
frame-relay interface-dlci 100
interface Serial2/1.101 point-to-point
description Enlace con CORPOSALUD
bandwidth 256
ip address 192.168.60.9 255.255.255.252
ip nat inside
frame-relay class voip256
frame-relay interface-dlci 101
interface Serial2/1.105 point-to-point
description Enlace Meteorologia
bandwidth 128
ip address 192.168.40.29 255.255.255.252
ip nat inside
frame-relay interface-dlci 105
interface Serial2/1.110 point-to-point
description Enlace Cana de Azucar
bandwidth 256
ip address 192.168.40.1 255.255.255.252
ip nat inside
no ip mroute-cache
frame-relay interface-dlci 110
class voip256cir256
interface Serial2/1.120 point-to-point
description Enlace Ocumare
ip address 192.168.50.1 255.255.255.0
ip nat inside
no ip mroute-cache
frame-relay interface-dlci 120
class voipprueba
interface Serial2/1.405 point-to-point
description Enlace Hospital
bandwidth 128
ip address 192.168.40.13 255.255.255.252
ip nat inside
no ip mroute-cache
frame-relay interface-dlci 405
class voip128cir128
interface Serial2/1.410 point-to-point
description Conexion La Victoria
bandwidth 128
ip address 192.168.40.21 255.255.255.252
ip nat inside
no ip mroute-cache
frame-relay interface-dlci 410
frame-relay ip rtp header-compression
interface Serial2/1.415 point-to-point
description Enlace Villa de Cura
bandwidth 256
ip address 192.168.40.9 255.255.255.252
ip nat inside
no ip mroute-cache
frame-relay interface-dlci 415
class voip256cir256
interface Serial2/1.420 point-to-point
description Enlace INPOL
bandwidth 32
ip address 192.168.40.25 255.255.255.252
ip nat inside
no ip mroute-cache
frame-relay interface-dlci 420
interface Serial2/1.425 point-to-point
description Enlace Barbacoa
bandwidth 64
ip address 192.168.40.33 255.255.255.252
ip nat inside
no ip mroute-cache
frame-relay interface-dlci 425
class voip64cir64
ip nat translation timeout 600
ip nat translation tcp-timeout 600
ip nat pool BvMBvA 200.44.49.135 200.44.49.141 netmask 255.255.255.240
ip nat inside source list 2 pool BvMBvA overload
ip classless
ip route 0.0.0.0 0.0.0.0 200.44.108.141
ip route 10.0.0.0 255.255.255.0 192.168.11.2
ip route 10.10.1.0 255.255.255.0 192.168.40.26
ip route 10.29.0.0 255.255.0.0 192.168.60.10
ip route 100.100.0.0 255.255.0.0 192.168.60.10
ip route 192.168.1.0 255.255.255.0 192.168.40.30
ip route 192.168.3.0 255.255.255.0 192.168.40.2
ip route 192.168.4.0 255.255.255.0 192.168.40.6
ip route 192.168.6.0 255.255.255.0 192.168.40.14
ip route 192.168.7.0 255.255.255.0 192.168.50.2
ip route 192.168.8.0 255.255.255.0 192.168.40.34
ip route 192.168.9.0 255.255.255.0 192.168.40.22
ip route 192.168.10.0 255.255.255.0 192.168.40.10
no ip http server
ip pim bidir-enable
map-class frame-relay voip1024
frame-relay cir 1024000
no frame-relay adaptive-shaping
map-class frame-relay voipovfr
frame-relay cir 128000
frame-relay bc 1280
frame-relay mincir 128000
frame-relay fragment 80
service-policy output voice-policy
map-class frame-relay voip256
frame-relay cir 256000
frame-relay fair-queue
map-class frame-relay voip256cir256
frame-relay bc 2560
frame-relay ip rtp priority 16384 16383 40
map-class frame-relay voipprueba
frame-relay bc 1280
map-class frame-relay voip128cir128
frame-relay bc 1280
map-class frame-relay voip64cir64
frame-relay cir 64000
frame-relay bc 640
frame-relay ip rtp priority 16384 16383 24
frame-relay cir 32000
map-class frame-relay voip128cir64
frame-relay bc 640
frame-relay ip rtp priority 16384 16383 45
map-class frame-relay voip64cir32
frame-relay bc 320
map-class frame-relay fragment40
access-list 2 permit 192.168.0.0 0.0.255.255
access-list 2 permit 10.10.0.0 0.0.255.255
access-list 2 permit 10.29.0.0 0.0.255.255
access-list 2 permit 100.100.0.0 0.0.255.255
access-list 2 permit 10.0.0.0 0.255.255.255
access-list 102 permit udp any any range 16384 37276
access-list 103 permit tcp any eq 1719 any
access-list 103 permit tcp any any eq 1719
access-list 103 permit tcp any eq 1720 any
access-list 103 permit tcp any any eq 1720
snmp-server engineID local 00000009020000E0FE06641C
snmp-server community Bethoven RO
voice-port 5/0/0
voice-port 5/0/1
voice-port 5/1/0
voice-port 5/1/1
dial-peer cor custom
dial-peer voice 200 pots
destination-pattern 200
port 5/0/0
dial-peer voice 201 pots
destination-pattern 201
port 5/0/1
dial-peer voice 100 voip
destination-pattern ...
session target ras
dial-peer voice 3400 voip
gateway
gatekeeper
zone local BIBLIOTECA BBVVA.COM.VE 192.168.2.1
no shutdown
La Victoria Site:
hostname La_Victoria
enable secret 5 $1$syG2$CRFKK/vAG.ui1osREeIOR/
class-map calidad
class-map signaling
class calidad
priority 36
class signaling
bandwidth 8
class class-default
fair-queue
memory-size iomem 25
ip subnet-zero
no ip domain-lookup
interface Serial0
bandwidth 128
no ip address
no ip mroute-cache
frame-relay lmi-type ansi
interface Serial0.410 point-to-point
description Enlace con Sede Principal
bandwidth 128
ip address 192.168.40.22 255.255.255.252
no ip mroute-cache
ip address 192.168.9.1 255.255.255.0
speed auto
h323-gateway voip h323-id victoria
h323-gateway voip bind srcaddr 192.168.9.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.40.21
no ip http server
frame-relay bc 1280
frame-relay bc 1280
snmp-server engineID local 0000000902000001422DCEB4
snmp-server community victoria RO
snmp-server packetsize 2048
snmp-server enable traps snmp
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps hsrp
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps frame-relay
snmp-server enable traps syslog
snmp-server enable traps rtr
snmp-server enable traps rsvp
snmp-server enable traps dial
snmp-server enable traps voice poor-qov
voice-port 1/0
voice-port 1/1
session target ras
dial-peer voice 260 pots
destination-pattern 260
dial-peer voice 261 pots
destination-pattern 261
gateway
Ok, couple things you might want to look into.
1) Several of the PVCs have no traffic shaping turned on at all. You'll need to shape all of your PVCs strictly to prevent oversubscription of the circuit. I'm assuming this is an E1 circuit? Make sure to traffic shape the same on both ends of the PVC.
2) You need to fragment all of the PVCs, even the ones not carrying voice since they share the same physical circuit. Again, this applies to both ends of every PVC. Fragment to the slowest PVC (32k?). 32k would be 40 bytes with a 10ms delay budget and 80 with a 20ms budget, I believe.
3) Depending on if you're attempting to oversubscribe any of these PVCs or not, you may want to set the DE bit on the non-critical traffic so if the telco discards, they don't discard your voice traffic.
Hope this helps.
Vance
Ok, thanks You Vance. I will apply your suggestions and later I comment the results to you.
Daniel.
lucy.west
Did you test Vance's suggestions for LLQ QOS for your voice traffic?
If so - what are the configs that you now use?
Lucy
jeff_caprock
Two things - limit your voice traffic to 96k, and apply an appropriate LLQ map class on both the 3660 and 1750 WAN connections that works with the CIR and how much bandwidth that you want to give to voice. One thing that can kill a voice connection is a 0k CIR WAN connection, which makes all traffic DE eligible regardless of being data or voice.
-Jeff
dgahm
Level 8
Level 8
If you do a "show policy interface " on one of your frame subinterfaces while a voice call is active you will see that the RTP packets are not hitting your priority queue. This is because you are trying to match on the access list, which does not work. If you set the IP precedence in your VOIP dial peers, then change your class map calidad to match IP precedence 5 instead of the access list you will have better luck.
