Highlighted
Beginner
Informacast Paging No Audio for Multicast
Hello
I am having issues using Paging with Mutlicast.
I have read that I need to activate IP-MULTICAST in router and/or switch L3. In my case it would be L3 but my IOS arent IPSERVICES so I can't activate multicast.
I was wondering if I put my Paging Server in the same Vlan that use my phones the audio go through succefully to my phones or anyway I would need to activae multicast?
Everyone's tags (3)
5 REPLIES 5
Highlighted
Rising star
Re: Informacast Paging No Audio for Multicast
It is layer 2 multicast at that point and uses IGMP snooping.
Look at the license you have supported do you supported IGMP snooping and layer 2 mcast?
Similar Thread
https://community.cisco.com/t5/switching/ip-base-license/td-p/2579539
Highlighted
Beginner
My Switches are L3 and I can't enable multicat because I don't have access to "ip multicast routing" command
So I want to know if I put my paging server in the same vlan that my IP Phone I still would need multicast
Highlighted
Rising star
The answer is yes liked stated above. It is layer 2 mcast.... see comment above about igmp snooping.
Show your exact model and licenses you ordered on the switch if you need someone to comment on it. The IP services model of licensing is a pretty old one, but I no longer quote licensing alot.
Highlighted
Beginner
Ok do you mean that now I have to enable just multicast in L2 with IGMP Snooping?
I think the commands should be:
ip pim sparse-dense-mode
ip igmp version 3
Under vlan de voice right?
Highlighted
VIP Collaborator
Yes, you need to configure those commands under your interface vlan. For example:
interface Vlan10
 ip address 172.16.1.1 255.255.255.0
 ip igmp version 3
Please check below document for more details:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/68131-cat-multicast-prob.html
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
