Quick question regarding port settings on a 4006 48port inline power blade. Should the ports be set to trunk auto or trunk off? The phones seem to function either way but I'd like to know which is correct.
You don't need to configure trunking on the ports. If there will be an IP phone connected and you want the voice to use one VLAN and a PC connected to the phone to use a different VLAN, you would configure this by using set port auxiliaryvlanx where x is the desired voice vlan to be used. See:
