Instalation problems with cisco call manager 3.3
obra
I need a callmanager that can work with noname machine under windows 2000 (I do not have ibm or anything like that) .
Can enyone tell me is this possible and if it is where can i find one?
Vance Krier
Level 4
Level 4
Your best bet is to pick up a DL320 off ebay for cheap. You should be able to pick one up for around $700. Something similar to ebay item 3048091306. Just make sure it has the IDE drives. Spirian won't install on the SCSI version without alot of hacking and believe me, its not worth it. You can get CM running on clone machines, but it takes more and more work with each version.
Save yourself the trouble and pop for the real deal.
Good luck,
Vance
Vance,
Unfortunately, I have the DL320 with 2 17GB SCSI drives and I'm unable to install CCM on it. I get through the entire OS install and then I get a BSOD -Inaccessible boot device. Do you have any tips on how to get around this?
Larry
