Integration between CMS and Huawei
alejandrortiz
Beginner
Beginner
We have installed a CMS with H323 module which call to Huawei. When the CMS stablish the call, the image is pixelated. Exist some behavior between two servers that generate this error? Some parameter to modify?
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
I have not seen any integration to Huawei, I don't think it was ever tested.
I'd start by looking at the supported codecs in both systems and find out if there's a common codec or not.
java
if this helps, please rate
Recognize Your Peers
