07-06-2005 07:14 AM - edited 03-13-2019 09:43 AM
I'have this messages from PRI to dial-peer for voicemail, but if i try to ipphone to voicemail respond correctly
Jul 6 14:46:33.880: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (Interface busy): IEC=1.1.182.11.26.0 on callID 4531 GUID=94D34FEAED6311D9A21EF287C10E204F
ITS_Teleco#sh voice iec de 1.1.186.5.7.6
IEC Version: 1
Entity: 1 (Gateway)
Category: 186 (Signaling socket failure)
Subsystem: 5 (H323)
Error: 7 (Socket error)
Diagnostic Code: 6
07-12-2005 08:37 AM
Check this bug-Id: CSCsa58719. your error message matches the one in the bug.
10-21-2010 07:29 AM
Hi there,
Can you provide more details please? I am having this same problem and I tried to check this bug but did my account did not give me access to check this specific bug.
Appreciate any assistance please, I really do not know why it is not working properly.
Thanks.
10-25-2010 08:06 AM
Assuming that you're running an IOS release newer than 5 years old the fix went into 12.4(2), you aren't hitting CSCsa58719.
It sounds like an issue with TCP sockets on the H323 leg. Can you get:
debug voip ccapi inout
debug ip tcp trans
debug h225 asn1
debug h245 asn1
debug cch323 all
Collect via:
Router(config)# service sequence
Router(config)# service timestamps debug datetime msec
Router(config)# logging buffered 10000000 7
Router(config)# no logging con
Router(config)# no logging mon
Router(config)# voice iec syslog
Router# term len 0
Router# sh logg
Also post 'sh run' of the device.
