IP phone 7941 Showing Ethernet Disconnected
kenng2086
Hi, all,
I am having an ineresting situation:
I tried to connect a 7941(phone A) to catalyst 3560, but the screen showed Ethernet disconnected. I used another phone(phone B) with good condition and connected to the same port on 3560, the same message appeared. I then connected phone A to a different port, it worked fine with the same cable. I also trid to connect a pc to the "faulty" port, the network traffic was fine.
Very strange, isn't it? Can anyone offer help to diagnose the problem?
pdaniels
100% faulty cabling problem. I have had this a couple of times before, replaced the cabling and the message did not re-appear.
Hardcoretech_2
I have the same issue and its the phone itself.
