Just some ideas to try...
Check the device load. Make sure this phone is getting the same load as the phone that are working.
Can you change the ring type?
When it does ring, does it cut out? Could this be a speaker/hardware problem?
And I assume you have reset the phone to factory defaults? Have you made any configuration changes on the phone or does it get all info from the TFTP.
