09-16-2002 12:18 AM - edited 03-12-2019 08:47 PM
Has anyone tried IP Softphone with a wireless LAN ??
I am concerned about voice QoS and welcome feedback on LAN QoS and also classifying the RTP stream to prioritise into the WAN to connect to CCM.
09-16-2002 04:26 AM
I am using IP Softphone and cisco wireless card. It works greate.
If you remember you need 80 Kb stream for voice, wireless suport 11 Mb link. There si no QoS problem.
Best regards
Aleksander
09-16-2002 05:01 AM
It really depends on the AP you are using. If you are using Aironet you will have better control than another such as Orinoco. Wireless can be extremely finicky, and Cisco recommends 7 or less connections per AP. I don't know what you LAN looks like, but do some serios research and testing before you launch! You can prioritize the WAN traffic in the IOS. Something like:
class-map match-any voice
match ip rtp 16383 16383
match ip precedence 5
policy-map policy1
class voice
priority percent 75
class class-default
fair-queue
Hope this helps,
geoff
09-23-2002 08:04 AM
I agree with Geoff. Do not deploy wireless unless you have an extreme need to do so and there is no other alternative. Apart from traffic management issues (the limitations APs have when processing calls), there are also a lot of issues surrounding security. This may be of less concern to voice than data, but is a concern nonetheless. You do not want folks listening in your 'confidential' calls.
Ade
