12-25-2004 12:21 AM - edited 03-13-2019 07:27 AM
i received the following Bill of Quantity to start a Cisco IP telephony instalaltion :
1- MID-MKT-IPC-K9-C: 3-Server, CCM 100 User Red., Unity VM 25 User Bundle, 3DES
2- LIC-CM-4.X-900U= :CallMgr 900 Usr License for MID-MKT-IPC-K9-B and C
3-UNITY-VMUM-USR: Unity, VM to UM Upgrade per user, no TTS
4-UNITY-UM-USR-E: One Unity UM for Exchange User.
5-CWITEM-2.0-ADD-K9:ITEM 2.0 WIN addon to LMS 2.X
6- ITEM-WS: IBM Workstation for Network Management Server (ITEM).
7-CP-7960G: Cisco IP Phone 7960G, Global (Attendant Console)
8-CP-7914=:7914 IP Phone Expansion Module for 7960
9-CP-DOUBLFOOTSTAND=: Footstand kit for 2 7914s
10-CP-PWR-CUBE-2: IP Phone power transformer for the 7970 phone
plus , of course, the Cisco voice gateway and the cisco Telephones set( include all types with their corresponding Licenses :7970G,7940G,7912G, 7920).
I am a newbie to Cisco IP telephony but i have practie with Other Vendors IP Telephony , could someone , please , help me to understand the use of each item mentioned above and if possible to pass to me some useful docs , URLs, User Guides , Sample configurations , or the minimum configuration required to have this IP telephony project running and working.
Sorry for that Long story , and its an urgent inquiry.
Thanks in advance for your help
Ali Ali
12-30-2004 01:55 PM
This is a standard Call Manager Bundle with Unity Voicemail licenses and User licenses
This is the Call Manager User Licenses
This is your Unified Messenging License for the application
This is a Single Unified Messaging License
ITEM is a Monitoring Tool that helps Monitor and troubleshoot your Cisco IPT
This is the Server that ITEM will be loaded on
This is a 6 button phone ususally for Exec or Receptionists.
This is a Sidecar to be used with the Receptionist phone that gives 14 more buttons to use.
this is another piece that connects the 7960 phone and the 7914 together.
this is the power supply for the Receptionist 7914 and 7960 phone,
If you do a search for callmanager one word on cisco's main site you can find so much information on the Call Manager, also with the software that you recieve you have a Doc's CD that will also have all of those documents.
01-01-2005 05:38 AM
thanks a lot for your reply ,
i have not recieve the software yet , i am in preparation phase ,
regarding item #1 , is that mean that cisco unity voice mail is bundled with Cisco Call Manager , so no need for separate Cisco Unity Server ? in other words will the Cisco Unity be integrated into the call manager ? so no need for integration configuration ?, or shall i configure the cisco unity separately ?
and i have not understood the difference between item#3 and item#4 , could you please elaborate a little bit?
Thanks in advance for your reply
ali.
01-03-2005 07:40 AM
Unity and Call Manager need to be on their own server. The licensing came in a bundle. as for items 3 and 4. This license enables you to integrate your voicemail system with an email system. you can integrate an exchange server with your voicemail server so you get your voicemail to your email and your email through your voicemail. Look up Unified messaging on Cisco.com and read about it. Its a very cool integration
