IPT ext mobility logout
auraycats
I use this link to provide log in service for extension mobility.
http://xx.xx.xxx.xxx/emapp/EMAppServlet?device=#DEVICENAME#
I understand the service will stop automatically after the preset timeout (8 hrs).
I can not find the link to log out ext mobility and returns to the ext default.
Is the log out link availble in Communiucation manager v6. It will help me a lot instead of read through the Cisco menu.
Ray From Singapore
schemberg
Hello Ray,
it is just one link/url for login and logoff. The EM recognizes if you are currently logged in or not and shows login or logoff dialog.
Kind regards
Axel
schemberg
Hello Ray,
Kind regards
Axel
