Community Helping Community
1234
Is there a design guide to configure Touchscreen in DMS 5.2??
I just got an (APR) ELO (3200L Digital Signage) touchscreen and I already have viedos running in it but now I want to go to the next level and configure a touch presentation. After going through the documentation I just found conection and calibration topics but nothing about the steps to design a touch presentation.
So if someone has a document that explains that, I'd appreciate if you post it.
Best regards!
1 ACCEPTED SOLUTION
Re: Is there a design guide to configure Touchscreen in DMS 5.2?
The "Touch" application, web page, or HTML is delivered or deployed the
same as other content.
Simply refer to the following Guides and this
should help.
User Guide for Cisco Digital Media Manager 5.2.x:
http://www.cisco.com/en/US/partner/docs/video/digital_media_systems/5_x/5_2/ dmm/user/guide/dmm52xug.html
User Guide for Cisco Digital Media Designer:
http://www.cisco.com/en/US/docs/video/digital_media_systems/5_x/5_2/dmd/user/ guide/dmdug.pdf
Content Creation Best Practices Guide for Cisco Digital Media Designer 5.2.x:
http://www.cisco.com/en/US/partner/docs/video/digital_media_systems/5_x/5_2/dmd/best/practices/guidelines.html
User Guide for Digital Media Player Device Manager:
http://www.cisco.com/en/US/docs/video/digital_media_systems/dmp/user/guide/5_x/ 5_2_x/dmpdmuse.pdf
Digital Media Suite API Documentation:
http://developer.cisco.com/web/dms/docs
The above documentation should give you the steps needed to deliver your
content to the DMP.  In Summary, most use cases have the content either stored locally or
delivered to the DMP via a Web\Content Server.
I hope this helps!
T.
5 REPLIES 5
There is no design guide for designing Touch applications.
Think of the Touch functionality as your finger as a mouse + click in
one step.  You can design simple web pages with click operations
or presentations with multiple touch features like an interactive
keyboard and other types of app functions.
Development of Touch applications is outside the DMS suite. What
i mean by this we (Cisco) do not design the Touch apps with DMD
or any other Cisco application.  The DMP & the Touch Display work
in tandem to use the custom application the you or a partner
develops.
I would contact one of our DMS partners like
industry weapon.  They develop applications like
this for Digital Signs.
Ryan Barlow
Account Executive
Cell: 412-916-7992
Email:  ryan@industryweapon.com
I hope this helps!
T.
Tom,
Let's say I already have the presentation, how do I load en execute it? Is it as simple as loading the "file" into the DMP memory or pulled from a webserver? Do I have to create a presentation in the DMD where I put the touch application and then push it to DMP as a normal presentation?
Any checklist or guide that explains this?
Regards!
should help.
I hope this helps!
T.
Highlighted
Hi Tom,
I already qualified this as a correct answer but I still have some doubts.
I got a Flash (swf) presentation that interacts with clicks which has an xml and html files atteched to it so that it can work when you reproduce it. So, here is where I can't figure out how to load this content into my DMS. I need to put this folder with the 3 files into the webserver then type the URL into the library to "call" the interactive file and once DMS uses the swf it will be brought from webserver as long as use the other files automatically although they are still in the webserver folder?
I hope my explanation-question was clear, if not I think I should go an open a case at TAC.
Thanks a lot!
Ok, I think I understand what you are saying and
this should work from the web server as long as
your .swf call for the other files has the entire
weburl embedded so it knows where to go..
If stored locally (just like on a PC) the .swf app usually
calls the files directly from the same directory of a sub-dir
of the app's root dir.
If the files are not to big and not confidential, upload them
here and I will test tomorrow in the office and let you know
what I find out.
Cheers!
T.
Content for Community-Ad
FusionCharts will render here
