ISDN - PRI NI2
c.shepard
I have a Cisco Call Manager V3.2, Cisco 3640 Router, and a Definity G3. The definity has a TN464F. We are trying to set it up so that we use ISDN PRI NI2. They still will not communicate with each other. The Cisco is setup for the
isdn switch-type primary-ni
Controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface Serial1/0:23
no ip address
no logging event link-status
isdn incoming-voice voice
voice port 1/0:23
mgcp
mgcp call-agent 172.16.20.11 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp profile default
dial-peer voice 9991023 pots
destination-pattern .
no digit-strip
port 1/0:23
The definity is setup for
ds1 circuit pack....
isdn-pri signaling
protocol version b
connect: network
interface companding mulaw
trunk group.....
group type isdn
service type tie
supplemenary service protocol a
The call manager is setup with a gateway and the endpoint is setup mostly with defaults.
Is there something we are missing? When calling from ip phone we get a fast busy. When calling from a non ip we get a fast busy. If we use the Trunk access code we get a slow busy.
15 Replies 15
mcnerney
Level 4
Level 4
You will need to define the IP extensions on the G3 to allow inbound calls from the PBX. I have a Nortel SL-100 and defined the IP extensions to point toward the trunk group connecting the gateway with the PBX. Next you will have to define route patterns for outbound dialing on the CM. For example, we use 5 digit dialing on the PBX so I set up a route pattern 6xxxx with a Called Party Transform of 766XXXX and in the same Partition as the sets. The PBX needs a 7-digit number coming inbound on a trunk group. For local calling I set up a route pattern 9.[2-9]xxxxxx with the same Partition as the sets and a discard Digits: PreDot. By stripping the 9 gave me the flexibility of using the same route patterns already defined on the PBX. Good luck.
cairns-a
You may want to try setting up the ds1 on G3 to connect: line-side. I have a simular set up and line-side works. Depending on the version of the G3, you may need to set up the links. Also, look to make sure you have a D-channel set up in the G3. How are you routing the call out of the G3? If you need help, email me. I have spend sometime making the G3 and a 3661 work together.
tcairns@estes-express.com
Both sides of your circuit are acting as user-side. Set the "Connect" field on the DEFINITY DS1 page (change ds1 xxxxx) to "pbx" and you will get a new field to the right called "Interface". Set this field to "Network". This now makes the G3 act as network side. You will need to take all trunks out of the trunk group and delete the signaling group first - the G3 won't let you change the DS1 settings otherwise.
In your trunk group, Page 1 -
set "group type" to "isdn", "COR" to whatever will allow calls to complete, "service type" to "tie", "Codeset to Send Display:" to 0 (zero)
Page 2 - "Send Name:" to "y", "send Calling Number: " to "y", "Send Connected Number:" to "y"
All other fields at default settings should work.
cairns-a
Here is good link on setting this up. http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis3600/sw_conf/pbx_int/36ldt1pr.pdf
I would like to know if the "connection" set to PBX then network, works. The G3 "connect" field on the ds1 is what the G3 is connecting to. If you had a PRI from the PSTN then you would want to set the "connect" field to network. Since you are connecting to a gateway and the G3 will act as the network, I think you would want to set the "connect" field to line-side.
I think the link will help.
Trae
I did not try that option. What I had to do to get it to work was reconfigure the cisco router a little. For some reason MGCP is not working. I tried multiple configurations and still got nowhere. I added a new dial peer below and deconfiged mgcp to get it working.
dial-peer voice 1000 voip
destination-pattern 73..
session target ipv4:172.16.20.11
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
ip qos dscp ef media
As far as the connect option I am set to network. However, I am not set to PBX.
Any thoughts on why mgcp is not working?
I'm not sure what you now mean by "not working". Anyway, I'm assuming the T1 is up (show controller t1 1/0) or you wouldn't even be having dial-peer problems ;^).
You don't mention what version of IOS you are running. For mgcp to work for digital facilities (T1/E1) you need to be running 12.2.11T1. If not, go no further until you upgrade the software. If you are, you're missing a couple commands that take the configuration from the CallManager. These are:
ccm-manager config server
ccm-manager config
After this CallManager will create parameters, dial-peers, etc.
Thanks I will try upgrading the IOS. I am currently on 12.2.8 T5.
I've used this quite a bit, even when I was at Lucent. The "Connect" field is what it is connecting to as you say, so when it is set to "Network" the G3 is acting as User side. When you change the connect field to "PBX" the "Interface" field appears (it is hidden until you change the connect field) and now you specify what the G3 will be acting as - network or user. So, the meaning changes.
I can guarantee you that the config I posted works, I've used it many many times.
So does this mean I will have a different result then I do now?
Everything is working except name passing which that option is turned on (set to Y on the G3).
And of course mgcp not working but that is probably due to an IOS problem as someone stated above.
Right now since the G3 is set as network (which is considered user to the interface type i am using) and the Call Manager is setup as Network (which of course means network).
If the PRI is up then your config. should be OK. It is just more usual to have the PBX as network side, but since you're using NI2 the 3600 can be network.
To get calling name going, go into the DEFINITY and on the first page of the trunk-group screen set "Codeset to Send Display:" to 0.
I changed the Codeset to 0 and it did nothing. My "service type" is set to tie. "Outgoing display" is y. "Send name" is Y "send calling number" is Y. "Send Codeset 6/7 LAI IE" is n
we've come a long way :^) Can you send the current router config and the current DEFINITY config (DS1, trunk Group)? I have not had a problem getting the calling name. The only issues, given the settings I've used, have been with calling number and that was because the "change isdn public-unknown-numbering" screen was not filled out. in the DEFINITY. Which way do you not get the name - IP to PBX or PBX to IP? Do you get the info after the call is answered?
Here is the router config.
version 12.2
service timestamps debug uptime
service timestamps log uptime
service internal
hostname RCB_MAIN_CISCO
logging buffered 4096 debugging
enable secret 5 $1$Wp6c$VLL86VRH3gm9gbm468s68.
enable password t0day
clock timezone Central -6
voice-card 1
ip subnet-zero
fax interface-type fax-mail
mta receive maximum-recipients 0
controller T1 1/0
framing esf
linecode b8zs
cablelength short 133
description Connection to Avaya Definity PBX
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
description Data VLAN
encapsulation dot1Q 1 native
ip address 10.1.1.6 255.255.0.0
interface FastEthernet0/0.10
description Voice VLAN
encapsulation dot1Q 10
ip address 172.16.20.1 255.255.255.0
ip helper-address 172.16.20.11
ip helper-address 172.16.20.10
no ip address
no cdp enable
interface Serial2/0
description Connection to South
ip address 10.4.1.17 255.255.255.252
serial restart_delay 0
interface Serial2/1
description Connection to Pryor
ip address 10.4.1.25 255.255.255.252
interface Serial2/2
no ip address
encapsulation frame-relay IETF
interface Serial2/2.17 point-to-point
description Connection to Broken Arrow
bandwidth 384000
ip address 10.4.1.9 255.255.255.252
frame-relay interface-dlci 17
interface Serial2/2.18 point-to-point
description Connection to Union
bandwidth 384000
ip address 10.4.1.13 255.255.255.252
frame-relay interface-dlci 18
interface Serial2/2.19 point-to-point
description Connection to Inola
bandwidth 384000
ip address 10.4.1.5 255.255.255.252
frame-relay interface-dlci 19
interface Serial2/2.20 point-to-point
description Connection to Collinsville
bandwidth 384000
ip address 10.4.1.21 255.255.255.252
frame-relay interface-dlci 20
interface Serial2/2.21 point-to-point
description Connection to Owasso
bandwidth 384000
ip address 10.4.1.29 255.255.255.252
frame-relay interface-dlci 21
interface Serial2/2.22 point-to-point
description Connection to Skiatook
bandwidth 384000
ip address 10.4.1.33 255.255.255.252
frame-relay interface-dlci 22
interface Serial2/2.23 point-to-point
description Connection to Training
bandwidth 384000
ip address 10.4.1.37 255.255.255.252
frame-relay interface-dlci 23
interface Serial2/2.25 point-to-point
description Connection to Owasso 96
bandwidth 384000
ip address 10.4.1.41 255.255.255.252
frame-relay interface-dlci 25
interface Serial2/3
no ip address
shutdown
ip default-gateway 10.1.0.91
ip nat translation timeout never
ip nat translation tcp-timeout never
ip nat translation udp-timeout never
ip nat translation finrst-timeout never
ip nat translation syn-timeout never
ip nat translation dns-timeout never
ip nat translation icmp-timeout never
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.0.91
ip route 10.2.3.0 255.255.255.0 10.4.1.18
ip route 10.2.4.0 255.255.255.0 10.4.1.26
ip route 10.2.5.0 255.255.255.0 10.4.1.30
ip route 10.2.6.0 255.255.255.0 10.4.1.22
ip route 10.2.7.0 255.255.255.0 10.4.1.34
ip route 10.2.8.0 255.255.255.0 10.4.1.6
ip route 10.2.9.0 255.255.255.0 10.4.1.10
ip route 10.2.10.0 255.255.255.0 10.4.1.14
ip route 10.2.11.0 255.255.255.0 10.4.1.42
ip route 10.2.90.0 255.255.255.0 10.4.1.38
ip route 10.3.0.0 255.255.255.0 10.1.0.74
no ip http server
ip pim bidir-enable
snmp-server community priv RO
snmp-server community pub RO
snmp-server chassis-id 0x16
call rsvp-sync
voice-port 1/0:23
echo-cancel coverage 32
dial-peer cor custom
dial-peer voice 9 pots
destination-pattern 9T
no digit-strip
direct-inward-dial
port 1/0:23
codec g711ulaw
dial-peer voice 7100 pots
description Claremore
destination-pattern 71..
no digit-strip
port 1/0:23
dial-peer voice 8800 pots
description Pryor
destination-pattern 88..
no digit-strip
port 1/0:23
dial-peer voice 1400 pots
description Owasso 86th St.
destination-pattern 14..
no digit-strip
port 1/0:23
dial-peer voice 1600 pots
description Collinsville
destination-pattern 16..
no digit-strip
port 1/0:23
dial-peer voice 6700 pots
description Skiatook
destination-pattern 67..
no digit-strip
port 1/0:23
dial-peer voice 4800 pots
description Inola
destination-pattern 48..
no digit-strip
port 1/0:23
dial-peer voice 1300 pots
description Broken Arrow
destination-pattern 13..
no digit-strip
port 1/0:23
dial-peer voice 3000 pots
description Union
destination-pattern 30..
no digit-strip
port 1/0:23
dial-peer voice 7000 pots
description Training Center
destination-pattern 70..
no digit-strip
port 1/0:23
dial-peer voice 7200 pots
destination-pattern 72..
progress_ind alert enable 8
no digit-strip
port 1/0:23
dial-peer voice 1001 voip
session target ipv4:172.16.20.10
codec g711ulaw
dial-peer voice 911 pots
destination-pattern 911
no digit-strip
port 1/0:23
prefix 9
alias exec sf sho frame-relay
alias exec sr sho run
alias exec ct conf t
alias exec i sho ip int brie
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
logging synchronous
login
ntp clock-period 17181529
ntp server 10.1.0.47 prefer
end
Trunk Group
Group Type isdn
CDR Reports Y
direction two-way
outgoing display n (This will display the trunk group name)
dial access y
busy threshold 99
queue length 0
service type tie
auth code n
testcall itc rest
testcall bcc 2
codeset to send 0
codeset to send national ie 0
max message size 260
charge advice none
supp service protocol a
digit handling enbloc/enbloc
trunk hunt descend
digital loss group 13
numbering format natl-pub (I have tried them all)
bit rate 1200
syncro async
duplex full
disconnect supervision in Y out N
answer supervision timeout 0
ACA Assignment n
measured none
wideband support n
internal alert n
mainten test y
data restriction n
send name y
send calling number y
used for dcs n
suppress # outpulsing n
number format public
outgoing channel id encoding preferred
uui ie treatment service-provider
replace restricted numbers n
replace unavailable numbers n
send connected number y
send ucid y
send condeset 6/7 LAI IE n
US NI Delayed calling name update N
DS1 Circuit pack
location 01b14
line coding b8zs
line compensation 1
framing mode esf
signaling mode isdn-pri
connect pbx
interface network
centreVu long n
country protocol 1
internetworking message progress
protocol version b
crc n
idle code 11111111
slip detection y
near-end csu type other
Signaling group
associated signaling y
trunk group for channel selection 11
supplementary service protocol a.
Let me know what I can do. I appreciate all your help.
