I can run a mpeg URL if it is posted in Media URL within DMP by clicking Start but if I try sending the same URL either through Startup URL or as a Job I get an error "Write enable the disc or try different folder."
Pankjb,
What is the format of the Video Content?
What is the sample URL that you are using?
What DMS-DMP version are you running on the 4305G?
In 5.2, There is a Startup "Media" & "Browser" URL. For "video" content you need to use
the MEDIA URL. I have tested and it works fine.
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
What is the format of the Video Content? MPEG.
What is the sample URL that you are using? http://10.1.10.10/test.mpeg
What DMS-DMP version are you running on the 4305G? 5.2
In 5.2, There is a Startup "Media" & "Browser" URL. For "video" content you need to use the MEDIA URL. I have tested and it works fine.
Yes when I paste this url in Dispaly Actions --> Media URL and press Start works fine. But the same URL I try to submit using Go To URL it gives error "Write Protected". If I give the same as Startup URL in Media - no display.
Please provide screenshots of the following screens from
the DMP-DM:
* Settings->Basic
* About->Hardware and Firmware Versions
You mention:
"But the same URL I try to submit using Go To URL it gives error "Write Protected"."
There is no "Go To URL" setting where are you seeing that?
thanks
T.
