Italy PSTN - External Phone Mask issue
Chi Fai Leung
E.164: +39 052 05243 XX (two digits' number range)
I am facing a external phone mask issue from CM --- VG (Italy ISDN BRI  ..... that is showing the wrong outgoing phone mask ... even I tried to fill the external phone mask as "+3905205243XX / 05205243XX / 5205243XX / 43XX / 05243XX / 4325 (exact match) " ... All external phone mask showed the wrong calling ID as outside "05205243" ..... I don't know why? Is it the variable number range on the ISDN?, .e.g. that can 05205243 or 05205243X or 05205243XX (the number range can 0 - 2)? If yes, then how can I make the external  phone mask on CM?
Manish Gogna
Check if there are any translation rules applied on the gateway or if the Service provider is actually changing the same. You can run a debug on the gateway to check what is coming in from cucm.
Manish
