11-01-2002 08:11 AM - edited 03-12-2019 09:23 PM
I have block 1900 and 1976 from my callmanager to prevent abuse, are there other codes that I should block. What about 809? How about the 20 other splits of 809? I just got some spam about 809 area codes being used to scam people like 1900 numbers. But Im not 100% sure I should block 809.
11-01-2002 08:50 AM
I've never heard of the 809 area code being a problem so I did some research and came up with this link:
http://urbanlegends.about.com/library/blnote11.htm
Basically, it says that everything regarding the 809 is basically true. With that in mind, as with any good access list, block it. Once all the changes have been made (and as a good practice) I would let your users know what you have blocked, that way if they have a legitimate 809 (there are some) number then you can fix it for them as opposed to them getting frustrated at the phone system.
Rick
11-04-2002 11:09 AM
Take a look at the following site. It list all of the area codes controlled by the North American Numbering Plan Administration.
Hope this helps.
11-04-2002 11:52 AM
Here is a list from the Cisco web site:
Country Area Code Blocked CM Pattern
Bahamas 242 9.1242xxxxxxx
Anguilla 264 9.1264xxxxxxx
Antigua & Barbuda 268 9.1268xxxxxxx
Barbados 246 9.1246xxxxxxx
Bermuda 441 9.1441xxxxxxx
British Virgin Islands 284 9.1284xxxxxxx
Cayman Islands 345 9.1345xxxxxxx
Dominica 767 9.1767xxxxxxx
Dominican Republic 809 9.1809xxxxxxx
Grenada 473 9.1473xxxxxxx
Jamaica 876 9.1876xxxxxxx
Montserrat 664 9.1664xxxxxxx
Puerto Rico 787 9.1787xxxxxxx
St. Kitts & Nevis 869 9.1869xxxxxxx
St. Lucia 758 9.1758xxxxxxx
St. Vincent & the Grenadines 784 9.1784xxxxxxx
Toll Charge Area Code 900 9.1900xxxxxxx
Trinidad & Tobago 868 9.1868xxxxxxx
Turks & Caicos Islands 649 9.1649xxxxxxx
U.S. Virgin Islands 340 9.1242xxxxxxx
