IVR call signal??
ruiandre
Greetings,
The todays problem:
In my IVR I want to redirect a call to an extension!
No problem so far!
Inside our Intranet when the call is redirected I can hear the calling sound in my phone, but when I call from an external number, I know that the call is "calling" but I can't hear the calling sound!!!!
Some clues????
Thanks for your attention!
Rui André.
5 Replies 5
dgoodwin
Asked and answered in the General forum. You are using an H.323 gateway. CallManager has now been enhanced to tell the gateway to play a ringback tone on the transfer, but the IOS H.323 software will need to be enhanced to allow this once a call was already in a connected state.
This does not happen with Skinny-based (and I believe MGCP-based) gateways.
My question is very direct:
In wich part of the router (VG200) configuration, may I find how to configure the ringback tones when a transfer ocurs?
Rui André.
Portugal - Leiria 36º
You can't. That is the problem.
my 3640 router has been configured as mgcp gateway, and i am encounter the same problem: when user calling from pstn to a cti route point, cti route point will redirect the call to an extension. there is no ringback tone.
Is there any fix for that?
Sara
skyluc
Generally, it´s a problem IOS. Use command " progress_ind alert enable 8 "in the dial-peer pots. This for version 12.2. OK!!
Luciano
