Highlighted
Beginner
Jabber Mobile doesn't stop ringing after pick up call via Jabber Client
I have an issue with Jabber Mobile, I hope you can help!
  • If I pick up the call via Jabber Desktop Client, then my Jabber Mobile App doesn't stop ringing until I cancel the call!
Any ideas?
Thank you!!
3 REPLIES 3
Hall of Fame Cisco Employee
Re: Jabber Mobile doesn't stop ringing after pick up call via Jabber Client
Is this on-prem? MRA?
java
if this helps, please rate
Beginner
it is via MRA!
Cheers
Then you'll need to review CUCM and expressway logs to find out if CUCM stops sending the ring alert to the device, or not, and then take it from there.
java
Content for Community-Ad
July's Community Spotlight Awards
