Jabber Mobile doesn't stop ringing after pick up call via Jabber Client
Gura24
I have an issue with Jabber Mobile, I hope you can help!
  • If I pick up the call via Jabber Desktop Client, then my Jabber Mobile App doesn't stop ringing until I cancel the call!
Any ideas?
Thank you!!
Jaime Valencia
Is this on-prem? MRA?
java
if this helps, please rate
it is via MRA!
Cheers
Then you'll need to review CUCM and expressway logs to find out if CUCM stops sending the ring alert to the device, or not, and then take it from there.
java
